fixed the engine. idles perfect now. which leaves me with only one single issue to figure out about this engine/car.
For info. Z18XE engine, with pressumed 92.000km on the clock (swapped engine). i have no proof of this milage being correct, but i feel confident it's around that,
everytime the engine warms up. a hollow ticking noise emerges from the timing side, but it goes away when you press in the clutch, which is weird since it's on the opposite side of the engine,
When the car is cold. the sound is not there, as the engine heats up to operating specs, the sound seemingly slowly fades in till it becomes loud like the video,
i've heard the following suggestions.
1 thrust bearing play on crankshaft? so when clutch is engaged. it pushes the crank to timing side, but idk if that would happen with cold engine, i'd imagine that'd mean it'd be 24/7
2nd suggestion was potentially a timing tensioner related issue? when the clutch is engaged the system has some pre load tension and that maybe the cause?
3. suggestion i heard was the inlet manifold glue having failed and causing ticking, however i do not believe this to be the case due to the location and sound of the tapping.
the timing has been replaced by a full GATES set, done it via the hayness manual guide, which was identical to the guide for z14xe and z16xe timing,
tightened. spin 10x. retightened. spun 10 times. check tension is at new belt indicated, and that was okay when engine went in,
i have just checked the timing again, the cam gears are in exact alignment, but the belt between the top cams feels honestly a slight hair lose? but unsure,
i have checked the plastic timing cap near the crank pully. and no play. the crank pully itself also does not appear to be moving,
Here video of ticking, at end. i press clutch pedal. sound disapears,
you can also see the timing belt move in and out on the pulley quite a bit to be honest. related?
I have ordered a engine stethoscope. should be here tomorrow.
